Thread: How many things are wrong with this picture
    Jul 2008
    Seacoast, NH
    250
    OK, my pool was opened on Monday. The motor on the pump wasn't working, so the pb came back today and replaced it.
    The water is cloudy and murky. Can't see more than a shadow of the bottom of the deep end.
    Here are my numbers:
    pH - Taylor test kit doesn't go below 7. Test strips say 6.8
    TA - 100
    FC - 0
    TC - 0
    CH - 150
    CYA - Very low. I wouldn't say it is zero, but you can still see the dot faintly when it is filled to the top.
    Oh, and by the way, the salt is very low too.
    I know I need to do some work on everything, but where would you recommend starting. I'm thinking I should start with a bunch of chlorine.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Feb 2008
    Denton, TX
    5,061
    Re: How many things are wrong with this picture
    I like your style. First, bring that pH up to 7.2 and then start with a bunch of chlorine. Use bleach. I would add enough this evening to get your FC to 12 and add enough CYA to get to 30. Keep the pump running and continue shocking until your FC holds overnight.
    Once you are finished shocking you can raise your CYA to between 60 and 80, add the salt you need, and turn on your SWCG.
    Jul 2008
    Seacoast, NH
    250
    Thank you. I'll report back if I need more advice.
    1.5 HP Pump
