Results 1 to 8 of 8
Thread: Jimk reporting for duty !
    Hello there ! I live in Burbank, California and have a smallish below ground pool. It's about 14' wide by 25' in length and I don't know too much about the equipment. I've been lurking for a while but I thought I would sign up and ask a few questions and seek advice. I have a weekly pool service and he does an OK job I think but it is a monthly expense I could do without. Judging from what I have read on here it shouldn't be too difficult for me to maintain my own pool so I may give it a go. When I got the pool (when I bought the house 10 years ago) it had a vinyl liner. Well that perished after about two years and I had a "proper" pool installed. So, that's where I am at !!
    15,000 gallons, IG, Plaster, Pentair 2000 DE Filter.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Jimk reporting for duty !
    Welcome to the forum
    You're done SLAMing when:
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    What's a "proper" pool?? :P
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    Quote Originally Posted by Melt In The Sun
    How rude of me, that came out wrong !
    30,414
    Hey, Jim,
    You will find tons of nice folks here willing to answer almost any question about pools. We're glad you're here!!
    Quote Originally Posted by Jimk
    Not rude, just not clear.
    Did you go to fiberglass or to white or colored plaster or to some of the pebble finish surfaces? You see, it makes a difference in what the right chemical balance is for your pool. The surface matters.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Okay, Jimk.
    Get out there and give my pool a good brushing, followed by a complete vacuuming. Also, the lawn needs mowing. And don't forget to edge. When you're done with that, there's a juniper hedge out front that needs topping. I'll find some more stuff for you to do by the time you're caught up
