Thread: Vacuum port
    jabsaw's Avatar
    Apr 2009
    Anaheim, CA
    36
    Vacuum port
    We are looking to install a vacuum port in the pool. Are there any suggestions?
    I believe we would need to have it below the water line, but does it need to be a certain depth?
    Also, I was wondering about flip covers to keep the hole covered while I have swimmers. Do they make such a item or should it stay open? We will have the jandy switch to turn the port off while there are swimmers. (Although I usually don't run the pump with swimmers.)
    Thank you for any input you may have.
    [center:30izqb54]Jennifer[/center:30izqb54]
    1) 25,000 gal 2) DE filter 3) In ground 4) Pebble
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Vacuum port
    For sanitation, you should be running your pump with bathers in the pool.
    jabsaw's Avatar
    Apr 2009
    Anaheim, CA
    36
    Re: Vacuum port
    I didn't know that. I usually shock the pool afterwards.
