Results 1 to 8 of 8
Thread: Help to get pool clear
    Trying for weeks to get water clear. Using liquid chlorine and trichlor in floater. Keeps registering 0 FC and TC Last night shocked after an hour numbers were
    TC 10
    FC 10
    TA 120
    PH 7.8
    TH 300
    This morning cloudy conditions and some rain last night but no sun today.
    TC 3
    FC 3-5
    TA 120
    PH 7.2
    TH 250-500
    CYA on Saturday at pool place was 60
    Water temp 68
    Using test strips ordering kit today so I can BBB been reading posts for the last weeks. Do I need to re shock again tonight until the FC holds to 10+ in morning? should I use more shock then last night is that why it didn't hold and how do I determine how much to use. Took the foater out because my CYA level is so high. Do I need to dump water? Thinking of adding Borates this weekend after get pool clear. Today I can finally see the bottom of the pool but still cloudy when I opened it was a swamp. Thanks for any help a newbee
    Central VA
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    Re: Help to get pool clear
    Yes, you should continue to shock and keep the shock levels up until it holds over night (no more then .5 loss). Use the pool calculator here http://www.poolcalculator.com/ to determine what level of shock you need to be at and how much to put in to achieve that level. I don't think you need to dump water, your CYA level may be ok as is, I would keep the trichlor out. Wait until you get the water clean before adding Borates.
    21x41 Oval AG pool. Vinyl liner, Hayward sand filter. BBB method.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    No you can manage with 60.
    Refer to the CYA Chart for your shock level- use the pool calculator to determine how much bleach to add.
    Your strips won't measure that high - so you'll have to maintain shock level as best you can till you get the kit.
    Hold off on the borates for a while - get to know your pool a bit better.
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    Glad to hear you are ordering a good kit. This will pay for itself quickly.
    You can run with a CYA of 60. It just takes more chlorine.
    Shocking is a process, rather than a one time event. You know when you are finished shocking when your overnight FC loss is 1 or less. You must get the FC in your pool to shock level and hold it there as best you can until the process is complete. With a CYA of 60, this means that you would need to raise your FC to 24. 10 is just not going to get you clear. Check out Shocking Your Pool for more information on that.
    Go ahead and start reading the Pool School articles and get familiar with things. Definitely stop using the tablets. You CYA is already high and those will just add to it. The best thing to shock with is simple household bleach.
    Thanks! I'll measure FC again this evening and use calculator to determine how much chlorine. I know I'm close.
    Central, VA
    Another concern are the bubbles on the top of the water can't seem to get rid of these. Does adding chlorine increase them?
    Central, VA
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    From my experience the bubble can sometimes just be the chlorine oxidizing things in the pool, mine stuck around for a week then went away on its own, shouldn't be anything to worry about. Yes sometimes it will increase with increased chlorine.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Thanks will just keep an eye on it for now.
    Central, VA
