Results 1 to 13 of 13
Thread: Daily maintenance
    Daily maintenance
    From the reading I have been doing, it sounds to me like the BBB method requires daily testing and topping up of chlorine. Is this true? Is it possible to do BBB without daily maintenance?
    Our pool is primarily only used by my husband and I we do our swimming in the late afternoons, that is, when it's not storming. We use the pool maybe 4-7 days a week.
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Daily maintenance
    Quote Originally Posted by MeSue
    Yes, it's true. Takes somewhere in the neighborhood of 1 or 2 minutes. Any pool should be tested fairly often for safety.
    Guest
    ANY pool, even those with SWGs or chlorine dosing systems should be checked daily for pH and chlorine levels. Once you really know your pool you can skip some of the tests and just test a few times a week because you will know how your chlorine lasts and how your pH moves and how often you need to make adjustments.
    Ohio
    217
    Hi MeSue
    I also check my pool and hot tub daily and I agree whatever system you would be doing should also be checked daily. There is little time involved in testing and things can be changed for vacation and other down time. By testing every day you will learn your pool 100%.
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    SW Indiana
    9,198
    Any sanitation system that doesn't monitor the sanitizer level will give you trouble if you don't test everyday. Chlorine consumption varies quite a bit from day to day. Sunlight, high bather load and mystery biological contaminants can reduce the chlorine to below the safe level pretty quickly. Regardless of chlorination method, safety dictates frequent testing.
    Mar 2007
    Sunny, Humid Central Florida
    30
    I agree with the other posters. I feel better if I test every day. Sometimes every other day, but less often than that and I get nervous that my water won't be just right. Maybe when I get to be a pro in a few years, I'll be brave enough to test once or twice a week.
    krcossin's Avatar
    Detroit Burbs
    113
    It takes me a few minutes in the morning before going to work to test CL & Ph, rinse out the skimmer sock. I add bleach and Borax if needed at night. Not that big of deal, I have missed several days, pool forgave me.
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
    okay, okay, ya'll convinced me! Doesn't seem like it's all that time consuming.
    Momof2... where in central FL are you? I'm near the Ocala forest.
    Sue
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Not to disagree....but I've been with BBB since May and I will test if I'm in the pool for CL and PH but if I'm not swimming I don't always remember to test....I haven't had any problems. MY CYA is about 70 and I keep the CL at least above 5pmm. I only shocked once and that was because I was leaving for vacation for 11 days. I added CL 3 days ago. You could add a little each day or a little more every other day, so long as your readings are in the appropriate range for your balanced water. My CL was a little high because I added too much CL the other day so I was able to go an extra day or two to let it drop back into my normal range.
    Sorry to ramble, hope that made sense.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    I test for FC, TC, and pH every day. It takes five minutes to run the test, swap out the skimmer sock and rinse the used one, add chlorine, empty the PoolSkim bag. I do this while the dogs are out in the yard doing their morning business. Yes, I know, I know. I should add the chlorine at night but it just doesn't fit into the routine around here. I test for TA once a week and CYA 3 times during the season.
    I taped a copy of Ben's Best Guess chart to the wall in my 'lab', an old camper topper set on a cement slab, has a sink and counter tops, cabinets to keep the chemicals, very fancy! Leaks bad when it rains though.
    Anna
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    frustrated,
    I'm curious, if you don't test, how do you know you are keeping the FC at or above 5ppm?
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Mar 2007
    30
    We're in Deltona. 15 miles southwest of Daytona Beach and 40 miles from WDW. Enjoy your pool!!
    Chris
    Riles_J's Avatar
    Nashville, TN
    218
    I'll be honest. I don't test every day. Sometimes only once a week, although on average 2-3 times a week. However, I feel comfortable that I know my pool's chlorine consumption rate and can add a jug of chlorine every evening or every other evening without testing and everything stays on track. My Ph stays put for the most part. The key is getting to know your pool. Once you are comfortable with that, you can pretty much predict where your levels are going to be without testing. Then daily testing may not be required.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
