Thread: Lamotte borac test strips
    Daytona Beach, FL 32117 USA
    I put in 6 boxes of 20 mule team borax in 12k pool. The pool calculator said I should put 9.3 four lb. Boxes. I tested with the strips after adding 3 boxes each time and the 2nd time around it looked like the strip indicated 50 ppm. The color looks about right, but the shade is not as intense as the color on the bottle.
    What are the expert's opinions on what I should do?
    12k Gal. Kidney IG pool (Built around 1964 screened enclosure?), Tahoe Blue Diamond Brite (Added 12/2007), 1 hp motor, Sta-Rite P2 pump, Hayward C900 paper cartridge filter, Resilience SWG PSC-3 SCC 25 Element, Dolphin Robatic Cleaner, Lamotte ColorQ Pro 11, Taylor K2006C, Lamotte Tracer PockeTester PH/TDS/SAL, purptiger
    Re: Lamotte borac test strips
    Those test strips are very approximate, the best option available but still tricky to be sure of the exact level. There is no "right answer" about what to do. You are probably fine where you are, but I would add a bit more borax, just to be sure your level will be good through the whole season, another box or two.
