I have been using the Pool Calculator. However, the PH measurement is always low. I add the recommended amount but do not get the expected result in change. It is about half of what the calculator indicates. Any ideas?
Depending on how long you waited before measuring the pH, it is possible that all of this aeration raised the pH some in that time so the drop in pH from the acid wasn't as much as you expected. If that were what is happening, you would see the pH rising over time anyway, even without adding acid, though the rate of pH rise will slow down as the pH gets higher.modog said:I do have a big waterfall and 2 scuppers. Is this causing it?
Go ahead and add chemicals. The CYA may take a week to dissolve 100%. Just be sure the water is circulating and that you don't add acid and bleach without some time between - an hour or so is fine. Personally, I add acid first, so I don't have chlorine bleaching out my sample.modog said:Thanks for the info.
Just waiting to hear back on whether I can add my bleach and MA after adding the CYA crystals directly to the skimmer. I backwashed my DE prior to this so I am good. How long before they dissolve? Is there a time to wait before swimming with adding CYA?
