Thread: First test
    Apr 2010
    Buckeye, AZ 85326
    619
    First test
    Hey all,
    My PB provided us with test strips along with our pool starter kit (brush, net, floating chlorinator & vac and hoses). I plan on buying a quality test kit but now isnt the $$$time$$$. The PB sent a guy out on Saturday to get the pool balanced and do all the mechanical start up. He will be back Tuesday to give me a crash course on how to care for and protect our new pool. When he was here Saturday he told me all I really needed to care for an Arizona pool is: Chlorine tablets, Acid and shock. That seems pretty simple to me and maybe a to good to be true.
    Here are my number from the strips.
    CI: 3
    TCI: 3
    ALK: 40
    pH: 7.6
    TH: 100
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: First test
    Too good to be true.
    When was the pool filled?
    Acid will be needed almost daily - you will have a difficult time managing with just strips.
    Did the PB add CYA? Are there tablets in the pool now, via chlorinator or floater?
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: First test
    Pool finished filling Friday morning. Not sure about the CYA. The chlorinator does have two tablets in it.
    2' Powerfall
    11,969
    Re: First test
    Ok, then read this:
    http://www.troublefreepool.com/pool-...aster_start-up
    You need to closely monitor your PH level to keep it below 7.8, this can drift very quickly in a new pool while the plaster cures. Frequent acid additions also lower TA, and I'm a little concerned with the TA level already being so low - can you get that checked with a drop based kit at a local pool store?
    I understand that $ is an issue right now but it's a small investment that will protect your $$$ investment - your pool. It's well worth the initial expense, believe me.
    Tablets in the chlorinator are a good idea while new plaster is curing, it helps keep the PH in check while providing chlorine and building your CYA level.
    But read Pool School - you can't rely on tablets all the time - eventually your CYA will get too high. Then you'll need to switch to bleach or liquid chlorine.
    Routine shocking is unnecessary in a properly chlorinated pool. Maintaining the FC according to the CYA chlorine chart should prevent any reason for having to shock.
