Thread: Sta-Rite Pool Heater Problem
    I have a Sta-Rite NA400 Natural Gas. This is it's 5th season. Last year in September 2009 the heater started to turn off after 30-45 seconds. It would ignite, heat, and shut down. Control board AFS light is lit. Also there is one flashing light in the Control Box grey panel. I replaced the AFS switch and the Thermal Regulator. Also replaced the wiring harness since most wires were chewed from mice and I had spliced them. The exhaust is blowing warm and fairly forceful. Sta-Rite tech support said that it sounds like a blower whci as you know is an expensive part to try out. Any ideas would be appreciated.
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    Re: Sta-Rite Pool Heater Problem
    Welcome to TFP!
    I can't answer your question. I just wanted to say hi! Hopefully someone who knows more about heaters will be along soon.
    22,543
    Have you tried lubing the blower bearings? Checking the cage for blockage might be something to do as well.
    You could check the rpm's if you have a tach handy. Some of those air flow switches are pretty sensitive and if the flow sags just a bit they'll trip.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    I know these heaters VERY well.
    You've has a mouse issue (infamous for these units) and I believe that there is a 'mouse house' in the blower unit that just needs to be removed so that it can do it's job, without constriction.
    I can walk you through checking this, if you need
    Luv& Luk
    -Ted
    If you can give me some instructions I'll give it a try..
    Central, VA
