Thread: Do you only need to shock if you have CC's?
    May 2009
    Jasper, TN
    249
    I just checked my FC and it was 1.5. CYA=50, PH 7.6, CC=0.
    My FC drops about .5 over night and drops almost 2 during the day even in cloudy weather, but water looks perfect, clear and sparkling.
    IF CC=0 then doesn't that mean there are no organics that the FC is eating? Do I still need to shock?
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Do you only need to shock if you have CC's?
    no need to shock...but you should target a minimum FC of 4...which means you should be raising your FC to at least 6 so that by end of day you will be around 4 and not lower...if you allow it to drop to 1.5 often, you will then develop CC's and need to shock...but every once in a while, no big deal
    Feb 2008
    Denton, TX
    5,061
    Agree with dmanb2b. Definitely run a higher FC.
    Mar 2007
    San Rafael, CA USA
    12,082
    In fact, you may find that you lose less chlorine on those cloudy days if you keep the FC level up at the proper level because the chlorine might be getting partially used up fighting nascent algae growth that isn't yet visible. Let us know about your daily chlorine usage after you maintain a 4 ppm FC minimum.
    May 2009
    Jasper, TN
    249
    Quote Originally Posted by chem geek
    Would that produce CC's?
    So having CC's is not the only time to shock?
    Mar 2007
    San Rafael, CA USA
    12,082
    Algae growth may or may not result in CCs, but it does result in extra chlorine demand. You can distinguish such problems from regular chlorine demand from sunlight by Performing the Overnight FC Loss Test.
    As for shocking, this isn't just when CCs are > 0.5 ppm, but also when the overnight FC loss is > 1 ppm or when the water has a lot of organic debris so may be cloudy (that isn't caused by water imbalance as with a high saturation index) or when there is any reason for extra disinfection such as a fecal accident or a dead animal, etc. Usually, though, when a pool is properly maintained you hardly even need to shock.
