Thread: Stupid test question
    Daytona Beach, FL 32117 USA
    35
    I test with both Taylor K2006 and Lamotte ph pocket tester and sometimes get numbers between the larger numbers on the iPhone pool calculator. For example, today I got 275 on CH which is between 270-280. I was not sure to base my calculation for increasing CH from either the 270 or 280 when raising to 300. The ph tester sometimes will give a figure of 7.45. Is this either 7.4 or 7.5. Maybe I am getting too worked up over these figures. I just figure that if I have spent so much money to test my pool that I might as well get it as close as possible.
    This is not related to the original post, but does absorbic acid get rid of scale? Thanks!!!
    12k Gal. Kidney IG pool (Built around 1964 screened enclosure?), Tahoe Blue Diamond Brite (Added 12/2007), 1 hp motor, Sta-Rite P2 pump, Hayward C900 paper cartridge filter, Resilience SWG PSC-3 SCC 25 Element, Dolphin Robatic Cleaner, Lamotte ColorQ Pro 11, Taylor K2006C, Lamotte Tracer PockeTester PH/TDS/SAL, purptiger
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Re: Stupid test question
    Quote Originally Posted by purptiger
    Be conservative when making adjustments--engage Pool Owner Patience. So, if your CH is 270, 275, or 280, and you want it to be 300, use 280 in the pool calculator and see how much it will take to raise it to 300. Then--very important!--add only a part of this suggested amount, run your system to circulate the water very well, probably for a day or two to be on the safe, patient side, and then test again. If you have patience and do everything in small steps, you won't overshoot your target with things such as CH which will be there until it gets splashed or backwashed out.
    Good luck!
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes, a little too "worked up" your numbers are fine with either kit.
    AA does not remove scale.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,730
    Quote Originally Posted by frustratedpoolmom
    FPM...sounds like "Sparklypoolitis" to me
