Thread: Hayward Leak?
    Hayward Leak?
    After I backwashed my filter today, I noticed a considerable amount of water running down the filter...
    I wiped it down and it was still slowly coming out...
    Is it just backwash pressure or is the oring/gasket going bad?
    There were a dozen or so little bugs fleeing the scene... right where the two piece seal ring comes together...
    -inBamaNow
    16x32 Hydra Liner, Hayward 24" Pro Sand Filter, WhisperFlo 1HP Pump, Hayward CL200, AquaChem Test Kit =[
    22,551
    Re: Hayward Leak?
    Did you try to tighten the split clamp a little with the pressure off of it?
    Re: Hayward Leak?
    No, I will though... I did tighten it, but the filter was on at the time... It wasn't lose at that time... I will definitely try it in the morning... thanks for the suggestion.
    The water did slow down to a very super slow drip.... but it was still wet just a few minutes ago.
    I have no idea who I was kidding... I went out as soon as I finished the post and got a good full turn or so more on each screw...
    -inBamaNow
    Aug 2007
    near the swamp
    806
    Re: Hayward Leak?
    tighten it with the filter off, and also press down on the handle to relief some pressure while tightening
