Results 1 to 7 of 7
Thread: Shock needed every 2 weeks for SWG pool?
    When we had our pool installed the guy told us shocking every two weeks isn't necessary for our pool and that it was mainly for above ground pools on a two week schedule. The local Pool guy is telling my husband he should be using Fresh & Clear (which is shock) every 2 weeks on a regular basis. I'm debating with my husband that it's uncessary since the first guy warned us of this. Can someone settle the debate?
    Nov 2007
    Rockland County, NY
    65
    Re: Shock needed every 2 weeks for SWG pool?
    I have a pool with a SWCG also. Generally I only shock on pool opening and closing. I might have to manually add bleach after a pool party but generally it isn't routinely necessary...at least in my experience.
    Rob
    27ft Above Ground Pool
    Sand filter
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Oh my goodness!
    You have been "pool-stored" via the Pool Guy! This is hogwash, and it has nothing to do with a SWCG or above ground pools. Somebody wants to sell you extra stuff that you don't need and certainly not on any 2-week schedule!
    Please go up to the top right of this page and start reading Pool School. It is well worth your time; it is an eye opener.
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    Shocking your pool based on an arbitrary schedule is not required. The only reason to shock your pool is if it needs it, as evidenced by: CC > 0.5 ppm, known organic contamination, FC loss of > 1 ppm overnight, or if you have a FC of zero (and even with a FC of zero, it still may not be required).
    There are a great many here who have never ever had to shock. I have shocked my pool once in all the years that I have owned it. Save your money (and your chlorine) and shock when the need arises.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by Melt In The Sun
    LOL that's what I was going to post.
    Oct 2009
    3,899
    My thread FPM!!
