Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Pool Store Analysis - I am confused!!
    Dawnm00's Avatar
    Apr 2010
    Texas
    11
    I know there will be someone on here that can help me out...
    Here is what my pool store analysis came back at today:
    FAC = 0
    TAC = 0
    CH = 190
    CYA = 110
    TA = 60
    pH = 7.6
    Copper = 0
    Iron = 0
    TDS = 550
    Pho = 200
    So, I am thinking based on the BBB method - I need 1 qt. 3 cups of bleach for the FAC number / and 34 oz. of Baking Soda for the TA number. But, what about the CH and CYA totals???? HELP!
    9,000 Plaster IG Pool & Spa
    Hayward Pro Series Top Mount Sand Filter System
    Mar 2010
    Spring, TX
    1,082
    Re: Pool Store Analysis - I am confused!!
    The only way I have read on this site to lower CYA will be to drain water, but I say WAIT until someone comes along with more info on that. Also there are products you can buy to raise CH if needed. Go ahead and fill out your signature with what equipment you have and this will help the pros out when they provide help.
    Welcome.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Without knowing your pool volume and type, I can't give you exact answers, but with your high CYA level, you'll need to raise your chlorine to around 12ppm as you can see on the Chlorine CYA Chart
    Your CYA is very high, and you really need to drain quite a bit of water to lower it. Readings over 100ppm aren't very accurate, so yours could be much higher.
    Check out the article Recommended Levels to learn more about your chemistry.
    Dawnm00's Avatar
    Apr 2010
    Texas
    11
    I added my gallons and filtering system to my signature...does this help with totals?
    SW Indiana
    9,198
    Quote Originally Posted by Dawnm00
    For your 9000 gallons, you'll need to add about 7 quarts of 6% bleach to reach the 12ppm recommended level.
    You also need about 5lbs of calcium chloride to raise your hardness with a plaster surface, but you really need to get your CYA down to a reasonable level before adjusting the CH if you can.
    Dawnm00's Avatar
    Apr 2010
    Texas
    11
    Do you suggest that I drain some of the water before adjusting any of these levels? Are you thinking about 30% drainage?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yes, drain water first. Otherwise you're just draining out chems you just bought! Assuming your CYA level is actually 110 (it could be a lot higher), a 30% drain would get you to about 80. Are you running an SWG? If not, you probably want the CYA a little lower, more like 50.
    Dawnm00's Avatar
    Apr 2010
    Texas
    11
    No SWG...question: What usually happens to make the CYA go so high? Last week chemicals were fine...GEEZ!
    Oct 2009
    3,899
    It usually comes from using chlorine pucks (trichlor). These constantly add CYA as they add chlorine.
    Dawnm00's Avatar
    Apr 2010
    Texas
    11
    Well, I am not using those anymore, after I read the Pool School posts. Any other thoughts?
    SW Indiana
    9,198
    You may need to drain more than half the water. CYA tests aren't accurate, particularly above 100ppm, so your real reading good be 150ppm or higher.
    The high CYA can make it very difficult to control an algae problem, and requires you to maintain FC levels much higher than most pool stores or test kits can measure.
    Dawnm00's Avatar
    Apr 2010
    Texas
    11
    There is no algae...the water is crystal clear.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,730
    how are you testing for CYA? TF100/Taylor K2006 or Pool Store? Pool store testing IMHO is about as reliable as strips...which is not good. Not saying some pool stores do not get it right...but it's hard to know which to trust.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by dmanb2b
    When I brought a sample in to the store, the day I bought a test kit (wrong one, by the way - now I have duplicates), they tested it using strips!
    There is no substitute for having your own, complete, test kit. Balancing pool chemistry without a kit is like painting in the dark. You'll create something, but it probably won't be any good, and you'll have just wasted paint.
    Dawnm00's Avatar
    Apr 2010
    Texas
    11
    This is a pool store that has quite a set-up...they use the liquid drops and then have the water circulator and they test for 10 different things. ??
    dmanb2b's Avatar
    Apr 2009
    NY
    3,730
    as long as you can trust them...but bottom line CYA does not fluctuate that significantly unless you add product containing CYA or replace water...otherwise it is testing error. One employee, may do better than the other..etc
    Dawnm00's Avatar
    Apr 2010
    Texas
    11
    One thing I forgot to mention...we had a significant amount of rain this past Friday. Water was tested today (Monday)...could that be it?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,730
    Quote Originally Posted by Richard320
    I absolutely agree...the TF100 is the best investment, I ever made toward my pool...period
    If you have 2" of rain (a lot of rain) in a pool with 4 feet of water you will have lowered the level by about 4%, which really isn't significant. Subsequent evaporation will probably bring the level back to where it was before.
  20. Back To Top    #20
    Mar 2010
    Spring, TX
    1,082
    I was the same exact way and the stores around me that test the water have all the same stuff. Problem is in a lot of pool stores, turnover is a big deal, may not be at yours, but they just do not get the training. I would suggest investing in a quality test kit, learn to do the test yourself, and you will get much better results. Plus having your own test kit saves times of having to go to the pool store to get tested and then they get you to buy this and that.
