Thread: Do I need a ground rod?
    Nov 2009
    Cleona, PA
    236
    Bought my Hayward 1HP pump, and it came w/ a 3 prong plug. It also has a spot for a grounding cable on the outside. Should I have a ground rod near my pump and ground it to that? Any specs I should know about for that? I believe the pool itself is an aluminum frame. Should it be grounded as well?
    13,500 Wilkes Vinyl AG (15'x30' rectangular)
    Hayward Power-Flo LX SP1580, 1HP
    Hayward S-160T High Rate Sand Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Do I need a ground rod?
    The clamp on your pump isn't for a ground, it's for the bonding wire. The bonding wire connects to your pool walls, ladders, dive stands, slide stands, fences, light housings, SWCGs and anything else conductive that contacts the water or could be contacted by a swimmer while in the water. IF your pool was installed according to code, the bonding wire should have been run to the equipment pad and left unconnected in the event the pump was replaced with one that had a bonding lug.
    Nov 2009
    Cleona, PA
    236
    Hmm... perhaps this pool was built before that requirement? (Not sure how old it is.)
    Here are some pics of my pool's pump area, with the pool shown:
    http://www.greatwhitedata.com/images/Pool/PIC_0265.jpg
    http://www.greatwhitedata.com/images/Pool/PICT0113.JPG
    Since the fence is attached to the frame, and the frame is in the ground, if the frame truly is metal does it still need grounded? (I could try to scrap some paint and see if it's metal.)
    SW Indiana
    9,199
    Quote Originally Posted by mkenyon2
    It has nothing to do with grounding. It is to connect everything together to ensure that anything which may become energized is at the same potential.
    Here's a link to a description that may be helpful Equipotential Bonding
    It has been code for a long time, so it's unlikely your pool precedes it. Your conduit for your outlet should be part of the system as well.
