Thread: Rain Rain Rain
    St. Louis, Mo.
    16
    Rain Rain Rain
    Hello, I've been looking at the site for a couple of weeks now. Great stuff. I've changed my method to the BBB"s. My question is. Here in St. Louis, Mo. its been rainy for the last 8 to 10 days now. Its supposed to let up on Tues & Wed, but back raining Thurs thru Sat. When do you I check and add your chemicals to the pool? When all of this is over? I don't want to waste alot of chemicals ,but I also do not want my pool to get too out hand. Appreciate any help.
    Thank You,
    Brett
    Grecian/W a Step style,14ft by 30ft
    14,000 gallon,Fiberglass,
    Sand Filter
    Deepend 5ft
    Method(BBB)
    22,551
    Re: Rain Rain Rain
    You need to check and add just as if it wasn't raining. Rain, unless it's an enormous amount, really doesn't affect the pool very much. Even that said you still need to keep the pool chems balanced every day.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Rain Rain Rain
    Here's a tip: you don't have to do the tests poolside.
    I use a piece of ½" PVC pipe as a pipette, grab samples from two spots and fill a 2 cup measuring cup, then carry that over to the patio table where I do the tests, sitting comfortably, with coffee and cigarettes in reach.
    If it's raining, I carry it in the house to do it. Just don't do it where you might spill and stain the carpet.
    St. Louis, Mo.
    16
    Re: Rain Rain Rain
    Thats A good idea on testing the water. I will test more often that way. Thanks for the advice you two. If I can just get some sun now so I can finish touching up landscaping.
    Brett
    Sand Filter
    Deepend 5ft
    Method(BBB)
