Thread: what order when installing wall foam and foam cove?
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Do I install the wall foam right down to the rail and the foam cove over the top of that or the foam cove and the wall foam from the top of the cove up? Thanks
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Feb 2010
    Houston, TX
    271
    Re: what order when installing wall foam and foam cove?
    I would think the wall foam would go all the way down, then the cove on top, but I really have no idea so don't take my advice on that.
    I just wanted to say good luck, hope the weather works out for you and you're swimming soon!
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    22,553
    John has it right. The wall foam goes all the way to the bottom and the cove inside of that.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Perfect. Thank you! BTW - half an hour ago the wind took the wall out of the bottom rail just as I thought all was going so well.... No big creases though but now I have to clean gravel out of bottom rail and get it back in there. Pulled the liner out of the pool so it's time to rock n roll on the grunt work!
    Feb 2010
    Houston, TX
    271
    Good guess on my part! It just made sense to me you wouldn't want a seam right above the cove, so I went with it!
    BTW,
    I've been wanting to use that one...but seriously, pics if you can!
    John
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I'll post pix at the other thread "Hurry up and Wait..."
