Thread: Should I worry about phosphates?
    Apr 2009
    Lancaster, pa
    71
    Have a 24' AGP..been hearing some talk from friends that have pools about phosphate levels..is this something to be concerned about or is it not that important?..Haven't seen too much discussion on this topic. I have "heard " that high levels can contribute to algea blooms?..was just wondering..been doing BBB method for last year with no problems, so I never did any tests for phosphates.
    Thanks!
    Curt
    24' AGP (13,600 gal)
    Sand Filter with 1.5hp pump
    Lancaster, PA
    Feb 2008
    Denton, TX
    5,061
    Re: Should I worry about phosphates?
    Phosphate levels are irrelevant. The main thing that contributes to algae blooms in pools is lack of chlorine. Properly chlorinate and you will never have an issue with algae.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Curt,
    What 257 said
    You can google phosphates, bottom left on page, and gets lots of reads that confirm.
    You gonna send your friends over to TFP? You know we can help them out
    You're done SLAMing when:
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Phosphates were the new buzz around here that kept the pool store in business last year....I spent/wasted money on phosphate remover and all it did was contribute to the 85 degree bubble bath I had last year. And I still fought algae because 1 ppm of FC was 'just perfect'...yah, for drinking the pool....
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by poolgirl22
    Apr 2009
    Lancaster, pa
    71
    Thanks guys for the fast responses...that is what I sort of figured, but wanted to make sure!
    Once again you all came through for me, just like last year when you all helped me through my Baqua conversion!!. Thanks a million!
    Curt
    Lancaster, PA
