Results 1 to 7 of 7
Thread: I lost one of my timer 'dogs'
    Somehow I lost my 'on' timer dog.
    Timer is a Intermatic P104T201.
    Does anyone know if they sell parts, or am I looking at a new timer?
    Other ideas?
    Thanks.
    Bill
    30,000 gallon vinyl / Starite pump, Sys 2 cartridge, Max-E-Therm 333k heater / Bioguard SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: I lost one of my timer 'dogs'
    poolcenter.com sells them, as do other places.
    Quote Originally Posted by JohnT
    Great!! Thanks!
    Will be checking them out at lunch.
    Jun 2007
    New Jersey
    653
    Or just drop by your local electric supply house. Most are Intermatic dealers and definitely will have the dogs. Or go here:
    http://www.intermatic.com/customer%2...0to%20buy.aspx
    Select "Distributor" in the drop-down menu and put in your zip. Unless you live in West Jockstrap, there will be one quite close to you. Don't bother with Retail Outlets, they usually don't have parts.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Apr 2008
    Central Texas
    326
    I've also bought them at Home Depot.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,029
    If an electrical wholesaler is too intimidating, look for an Ace Hardware. They can order them if they don't have them in stock.
    I googled the part # from poolcenter.
    There is an Ace hardware on the way home and they have 4 in stock. Will pick up an extra.
    Thanks everyone!!
