Thread: How do my numbers look?
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    I had CYA issues but I think I'm back under control. I just wanted to check to make sure all looks good.
    FC 3.5
    CC 0
    pH 7.6
    TA 90
    CH 130
    CYA 40
    I've had 3 pucks in floater for the past week to try to increase CYA from 30. I haven't added any bleach until today when it dropped to 3.5. Floater is now empty. I added 9 cups of bleach to get to target level of 7. Pool is in full sun so I've been trying to keep FC on the higher side of range. I was previously losing about 3ppm a day. Should I continue increasing CYA to 50 because of full sun, no trees, no shade until almost 7:30pm?
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    Feb 2008
    Denton, TX
    5,061
    Re: How do my numbers look?
    Looks good to me.
    You can increase your CYA if you want to or you can stop where you are. I would probably stop there and add CYA later if needed. It's easier to add some than to remove some.
    Butterfly's Avatar
    South Carolina
    10,045
    Numbers look good
    All day full sun? If it was my pool, I'd increase CYA to 50-ish.
    With a sand filter, you will be backwashing some out anyway.
    You're done SLAMing when:
    esim13's Avatar
    Oct 2009
    320
    Yes, all day full sun! I have 4 1/2 days of teaching left then lookout pool here I come
    GEAUX TIGERS!
    Pics taken 2012
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by esim13
    That reminds me - I need new sunglasses
