Results 1 to 7 of 7
Thread: Getting better coverage from my Polaris 280?
    Sep 2009
    Madison, AL (north AL)
    77
    I have a freeform pool that is somewhat kidney-shaped. It is pretty standard with a 4' shallow end that tapers gradually down to about 9' in the deep end. My 280 cleans the heck out of the deep end, but it doesn't want to spend much time in the shallow end. I'm afraid that it has alot to do with the shape of the pool. When it comes up toward the shallow end (usually coming up from the deep end along the outside wall of the pool), the concave part of the kidney shape guides the unit diagonally across to the other side. Most of the time, it seems to hit the other wall and then continue to turn counterclockwise and head right back down to the deep end. Does anyone have any ideas to get better coverage in the shallow end?
    Phillip
    25k gal IG freeform pool, gunite/plaster, built in 2006; Aqua Logic AQL-PS-8 control w/ T-CELL-15 SWG; Sta-Rite S8M150 cartridge filter; Sta-Rite SR400NA gas heater; Polaris 280
    South Central NJ
    3,192
    Re: Getting better coverage from my Polaris 280?
    If the hose and the backup unit doesn't leak, the pusher jet may need a push to one side or the other.
    Scott
    Owner of - PoolGuyNJ LLC
    Apr 2008
    Central Texas
    326
    Also look VERY closely at the drive teeth on the inside edges of the wheels. Just one or two broken teeth can cause that wheel to "pause" momentarily on each rotation, causing the Polaris to always want to turn towards the other side.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Aug 2007
    near the swamp
    806
    thrust jet should be straight back
    Sep 2009
    77
    Thanks guys, great advice.
    I'll look carefully at the drive teeth. I do know that the tires themselves were replaced late last summer.
    Pusher jet / thrust jet, same thing? I've seen the small 1-2" tube that points out of the lower-back of the unit. Is that it? I think it's pointed at an angle, and I've been wondering about that thing.
    South Central NJ
    3,192
    That's it. It's on a ball end so you can move it.
    Scott
    Sep 2009
    77
    You guys are great. I really appreciate the advice. The jet was at an angle, so I moved it to the straight-back position. More importantly, I checked the wheels, and sure enough, about HALF of the teeth of the wheel on the single-wheel-side were completely gone. No wonder it was turning too much to the left! I'm just new to the Polaris, so your experience is invaluable to me.
    I went to the pool store today to get a new wheel, and the guy was nice enough to let me know that the rear wheel on the 2-wheel side was not gear/spindle-driven, so it really didn't need teeth. So, I just swapped those 2 wheels. Pretty nice of him, I thought.
    Thanks again,
    Phillip
