Thread: anyone tried a Jandy touch?
    Has anyone installed or upgraded to a Jandy Touch system?
    I'd love to know what specific functionality improvements it has over the RS 8 late model software.
    It would be great if I could do temperature based switching. i.e. use solar priority heat the pool to 83 then switch to the jacuzzi till 104-
    Uncle Dave
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
    Re: anyone tried a Jandy touch?
    Quote Originally Posted by Davegvg
    Uncle Dave
    My controller motherboard went bad on my RS and it was cheaper to buy the Touch upgrade kit then to just buy a new motherboard (comes with new motherboard and new inside control panel for less then an RS motherboard) . I like the Touch system. I have more control, easier programing, and lock-out control for renters. I can also see everything that is going on at one time because it has a display screen instead of the single row of scrolling text.
    As for your specific question, give them a call or talk with your local dealer.
    Pool #1 IG 24k Diamond Brite plaster with spill-over spa. Jandy Aqua Link RS One Touch with built into pool floor cleaner. Jacuzzi Magnum pump/basket feeding Hayward top mount Zeosand filter. Jacuzzi Magnum pump/basket for Spa Jets. Heat Siphon pool heat pump. Dolphin Robotic pool cleaner.
    Pool #2 IG 35K 20X40 Vinyl. Hayward top mount Zeosand filter with Pentair 3 HP IntelliFlo VS+SVRS. Chemical Free pool using Water Doctor Copper Ion Generator, PoolSkim, Polaris 9300 Sport robotic pool cleaner, Heat Siphon pool heat pump, solar blanket, Ameri-Dome 50X30 dome enclosure during Winter.
