Thread: Polaris 380 replacement booster pump
    sktn77a's Avatar
    Chapel Hill, NC
    146
    Hello:
    My Polaris 380 booster pump (I believe it is the origina PB4-60, not the Halcyon Q model) is 15 years old and has always been noisy. However, this season it's gotten so loud you can't hear a conversation if you're sitting close to it - sounds like its about to self destruct. I would like to replace it with a quieter pump from a different manufacturer and also a less expensive one, if possible (I've heard other polaris pumps and they're all too noisy).
    Any recommendations (based on successful installations) on a quiet 110v pump with 1.5" fittings?
    Thanks
    Keith
    Keith
    15,000 gallon in-ground gunite/plaster pool, 1.5" PVC plumbing
    1.0HP Sta-Rite DuraGlass P2R pump, Hayward S244T sand filter
    Teledyne-Laars Lite-2 250k heater, Hayward CL200 chlorinator
    Polaris 380/Hayward 6060 booster pump
    Jan 2009
    Cupertino, CA
    1,966
    Re: Polaris 380 replacement booster pump
    I don't really know from pumps but I have a PB4 and I don't think it's all that loud. Being inside the shed helps of course, but even with the doors open it's no problem to hold a normal conversation right there. So I would first suspect something reasonably repairable, like needing new bearings. Hopefully someone mroe in tune with pumps will be able to answer with more confidence.
    --paulr
    BBB "Intermediate Swimmer"
