Results 1 to 11 of 11
Thread: Pool temp is 187F...
    matj6876's Avatar
    Jul 2007
    DFW, TX
    87
    ... OK not really, it's 74F, but that's what the equipment is reading!
    Intellitouch i5 system with an all Pentair supporting cast including MasterTemp heater.
    I noticed a few weeks ago that the water temp sensor would intermittently indicate the pool was boiling and thought nothing of it. Hey, I have a regular pool thermometer that I trust more than that reading anyway!
    Now I come to heat up the spa and, of course the system thinks the water is over 102F and won't spark up the heater.
    (As a side note I cannot get it to start manually but that's more than likely use error.)
    My initial reaction is that the sensor is on the fritz and replacing it should do the trick.
    Something like this for ~$50 looks like the exact match:
    http://www.aqua-man.com/row_num.asp?ic=2416&froogle=1
    Before I go ahead..... I thought I'd check in here and see if anyone wiser than me has any pointers?
    Thanks in advance
    My Pool: 27K gal IG plaster, Pentair FNS Plus DE Filter, Intellichlor IC40 SWCG, Polaris 280 Cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Pool temp is 187F...
    Quote Originally Posted by matj6876
    (As a side note I cannot get it to start manually but that's more than likely use error.)Check connections for looseness/corrosion. Temperature sensors work off resistance, so a bad connection can cause problems.
    Thanks in advance
    I wish I knew the parameters. In the car world, unplugging a sensor gives us a reading of -40F. Shorting the plug reads 273F. If those work, it's the sensor. But I don't know what pool electronics use, so that's just as an example, not as anything you should use for diagnosis.
    22,539
    Different applications fail different ways. In the industrial world the default is to have and open thermocouple fail high. A shorted T/C reads ambient.
    Well, when my heater started acting strange, I called the local pool company that inspected the pool when I got the house a few months earlier.
    That is the part he replaced. Cost me $275. Next time, I'll try to replace that part myself!
    The sensor can go bad, but usually it is a problem with the cable between the sensor and the control unit. Check along the cable and see if it is nicked or cut anywhere and make sure it is fully connected to the control unit.
    One thing that you could try is flip flopping the wires between the air temp sensor and pool temp sensor to make sure that it is a bad sensor and not a bad board.
    HD
    The Arcadian Dragonfly
    20,000 Gallon, vinyl IG with sand filter.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Just gonna throw my $.02 in here =
    The thermistor sensor is probably shot The thermistor is what reads the temp of the pool water.
    Luv& Luk
    -Ted
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    I had a thermistor prob too, didn't much matter for heat but it sure did for freeze protection, had to replace it, luckily was under warranty as it was only a few months old. Ha you had me hooked 187, I thought wow I could cook a hotdog in his pool
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Its the temp sensor, you can find it drilled into yaud return line.It has a small low voltage wire from your intellitouch to temp sensor. Looks identical it the air sensor
    matj6876's Avatar
    Jul 2007
    DFW, TX
    87
    Yep - I should have come back and closed this one off. It was the sensor. $40 replacement part and about 20 mins to replace. Local Pool place wanted $250 parts & labor... so I saved a buck or two on this one. Thanks for all your help and suggestions.
    Mar 2007
    4,160
    Less expensive and efficient - that's we're all about
    I'm happy your issue was so easy to resolve!
    Luv& Luk
    -Ted
