Thread: Easy Set Year 2 Chemical Confirmation
    May 2009
    Corning, CA
    22
    I'm getting ready to set up my Easy Set pool for season 2. Last season, I discovered the Trouble Free Pool forum AFTER I had it setup and had purchased trichlor tabs and all the other silly stuff that friends suggested. I bought the TF 100 test kit and switched to BBB after the CYA level reached 30 and am happy to say I made it through last summer with NO algae outbreaks whatsoever.
    This year I want to start out following the Guide for Seasonal/Temporary Pools and just want to confirm some of the products I am preparing to order. I have found Dichlor and Polyquat 60 at the following links and just want to confirm that I am buying the correct stuff.
    http://www.spadepot.com/shop/Dichlor...b-P618C43.aspx
    If I am reading the guide correctly, I need 2.5 pounds. They come in 1 pound containers so I'll get 3.
    http://www.poolgeek.com/ProTeam-Poly...ign=googlebase
    How much Polyquat would I need assuming a 5400 gallon pool and a swimming season of 16 weeks?
    Thanks for the help and thanks for the great site.
    Dave
    Intex Easy Set 18' x 42" AG
    5400 gal
    Intex Krystal Clear Model 635 pump, 1500 gph
    Type "A" cartridge filter
    Jan 2009
    Cupertino, CA
    1,966
    Re: Easy Set Year 2 Chemical Confirmation
    That's the dichlor, and that's the polyquat 60.
    As for amounts of PQ60, that web page says initial treatment 6 to 11 oz per 10,000 gallons, and maintenance dose 2 to 4 oz per 10,000 gallons. So for your pool, 3-5 oz initial dose and 1-2 oz weekly after that. If you're good about maintaining the FC, I'd say use 1 oz weekly; if you have trouble, go with 2 oz.
    It's a quart bottle, so one should last you the season.
    --paulr
    BBB "Intermediate Swimmer"
    May 2009
    Corning, CA
    22
    Quote Originally Posted by PaulR
    --paulr
    Oops . . . I guess I should have read the whole page.
    Thanks for the info though.
    Dave
    5400 gal
