Thread: Plaster vacuum in a vinyl pool
    Columbia, SC
    22
    Is there any reason I can't use a plaster vacuum to clean my vinyl pool? I find the wheels glide better along the bottom than does the bristles from the vinyl vacuum head.
    20K gal, vinyl, 3/4 HP pump, Hayward sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Plaster vacuum in a vinyl pool
    The wheels can leave tracks if the bottom is soft, which will cause sediment to settle there. They can also cut the liner.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    What Richard said!
    Luv& Luk
    -Ted
    Columbia, SC
    22
    Thanks Richard and Waste
