Thread: How long to run pool cleaner (polaris 280)
    Dallas, TX
    227
    Just curious, how long do most Polaris owners run theirs a day? Do you leave it in the pool when not on? Heard they last longer when pulled out, especially when adding chemicals. I don't fully buy that so i thought I'd check.
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    Jan 2009
    Cupertino, CA
    1,966
    Re: How long to run pool cleaner (polaris 280)
    My 380 stays in the pool 24/7 except when we're swimming. The way I read the manual, it's intended to be that way. (Hard to imagine how you can run the thing on a timer, if you take it out all the time.)
    I run mine 2-3 hrs/day depending on the leaf count. That varies a lot though; I think geekgranny runs hers about 48 hrs/day. (She has a major silt issue.)
    --paulr
    BBB "Intermediate Swimmer"
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by PaulR
    --paulr
    Well you were close. 36 hrs per day.
    Actually I've got it down to five 2 hour cycles per 24 hr day. That is as long as I use the Polaris Disposable EZ bags. They filter out a lot of the microscopic "powder". The bags I made from allergy fabric (like used on allergy pillow and mattress protectors and frost cloth for plants) were filtering too finely so they clogged in a few hours. I'm still experimenting with design and "fabrics" though. The EZ bags are really expensive and I go through one every couple or three days, and that's emptying them. (they don't have an opening at the large end like the regular filters so I clean them out similar to cleaning out a Slime Bag.) After three days the "fabric" begins to deteriorate so that holes begin to form.
    Before using Fiber Clear and the EZ bags, and Pool Skims, over many years, I ran the Polaris round the clock some parts of the year. I'm getting into somewhat of a groove now and see the light at the end of the tunnel, with some of my recent experiments, the new Quad 80 filter, new VF pump and Fiber Clear cellulose.
    Many people can get by with a few hours a week. My neighbor, who has more grass cover than I, so much less dust, and only one old dog, who spend most of her time over here kicking up dust with my pack, and an automatic cover does run her Polaris several hours a day but could go longer if she was as finicky as I am.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Mar 2009
    eastern washington state
    275
    mine runs about all the time, I don't have it on a timer so i just leave it on. The way I look at it, more is better!!!!
    but lets be honest here, the more you run it the more wear and tear on it and its going to wear out faster, or should I say your going to be replacing parts more often.
    but I love mine!!! She is a big help.
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    run the 280 for as long as it keeps the pool clean, this could be 1 hour per day to 6 hours per day depending on the amount of debris is in the pool, but remember the 280 has gears and cogs so the more you run it the quicker it will wear out. On average it should take about 3 hours to clean a standard size pool.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Dallas, TX
    227
    Thanks for all the responses. I have set the timer to two hours in the early evening so we'll see how that works.
