Results 1 to 19 of 19
Thread: Leveling the Ground for Intex Ultra Frame Pool
    Dayton, Ohio
    79
    Just bought one of these. I would like step by step instructions as to how I go about leveling the ground. Intex specifically says NOT to use sand to level the ground. I know that I need to take earth from the high side but am not sure how to go about doing it and making sure it is level. I am prepared to rent a manual sod cutter but in no way want to hire this out. Can anyone help me? Pix would really help!
    Cindy
    AG Intex Ultra Frame
    Round 16 ft x 48 in, 5061 gal
    2500 gph Intex Krystal Clear Cartridge Filter
    BBB
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Leveling the Ground for Intex Ultra Frame Pool
    Hi Cindy...welcome to TFP
    here is a helpful link...after the dirt is leveled, just use 2-3 inches of sand to protect the liner and provide a soft bottom.
    http://www.ehow.com/how_2214568_leve...ming-pool.html
    Dayton, Ohio
    79
    But it specifically says NOT to use sand?
    BBB
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    do not use sand to level...but do use it to protect your bottom. If you prefer not using it, then just put a tarp down over the leveled dirt
    Dayton, Ohio
    79
    Thanks you so much! THAT is the specific info I need. Much appreciation!
    BBB
    Quote Originally Posted by cmbutterbaugh
    I leveled my area with sand, and then put a tarp over it, which also keeps the sand from getting in the pool on the wet feet.
    Jun 2007
    MA
    165
    We levelled wih sand and use a gorilla pad
    Cheryl
    14X42 Intex Ultra Frame
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Cindy,
    Welcome to TFP!
    You asked for a step by step. Here you go!
    Steps that I used to create my origninal pool area:
    1. Choose area, use a can of marking paint to paint a circle 2' larger that your pool. ie 18' pool = a 20' circle.
    2. Cut sod off and dispose of. (if you do not do this it rots and stinks terrible)
    3. Attached a 4' level to a 10' 2" x 6" pegged to the middle of the circle.
    4. Swing board in a circle trimming away any high spots and filling in any low spots.
    5. Tamped entire area with a hand tamper. (lots of work, rent a plate compactor it goes alot faster and not as hard on the back and shoulders.)
    6. Put down 1 1/2" or 2" styrofoam (the pink stuff). Tape the seams with Gorilla tape. Cover it all with a HD tarp. (don't use the tarp that they send with the pool, get a good HD one)
    7. Setup pool, place 1 1/2" or 2" pavers/patio blocks under the legs.
    8. Fill pool with 2-3" of water and smooth all wrinkles out.
    9. Fill up the pool with the rest of the water.
    10. Test water with your new TFTest kit (you did order one right?) use results on The Pool Calculator and add BBB (if needed) to your Pool.
    ENJOY THE POOL!!!!
    Mike
    PS, I did eliminate a few steps. Like go to store buy beer. Go to store buy AsperCreme for the aching muscles. Go to store buy more beer. LOL
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Dayton, Ohio
    79
    LOL!!! I sure won't forget the beer! I never heard of using styrofoam. Is it just for comfort? I mean, I grew up swimming in concrete pools so I wasn't really worried about that. Thanks for the the great step by step!
    BBB
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    The styrofoam use is 3 part - comfort - alot easier to walk on, protection - protects the pool bottom from rocks, weeds and other nasties, insulation - insulates the pool from the cold ground. I have been using the foam since we bought our 1st pool ( 6 x 10 ) and set it up on the concrete patio. I learned about it from a friend that put it under his 24' perm AG close to 15 years ago and still has the same foam and liner in.
    I just remembered another step:
    5.5 Spray area with herbacide and insecticide of your choice.
    Aquabot Pool Rover
    Dayton, Ohio
    79
    Ok, thanks. So, I guess I can just pick this up at Lowes or Home Depot and cut down to size, right?
    BBB
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Right, I bought mine at Menards but Lowes and HD carry it also, just check around for the best price. Not sure about the pink vers. blue vers. yellow, I used pink, my friend used the yellow and I also have seen the blue at HD.
    Aquabot Pool Rover
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    i just finished putting up my 16x48 ultra frame and it turned out real good. i'm off no more than 2'' all the way around so i guess it evens out. pool is real sturdy and the grandkids had a blast this past weekend. i used strings tied to stakes around the perimeter of the pool and using a 2ft level we dug out the outline of the pool until level starting with the high side to match the low side. i also bought some liner shield online based on online reviews to put under the ground cloth for added protection. and i have built a deck around one side of the pool which has turned out to be great! the kids jump off the deck right into the pool. the water has remained almost totally clear of dirt and grass. bought a pool ladder that attaches to the deck. ah, the good life!
    i will post some pics shortly....been pretty busy!
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    Dayton, Ohio
    79
    Thanks for all the advice I REALLY appreciate it!
    BBB
    Jun 2013
    Southeastern British Columbia
    79
    Question about the area needing to be level for a rectangle pool... Do I need 2' on all sides? So for 13x24 I would dig 17' x 28'?? That is soooo huge it's daunting.
    13 x 24' x52" ultra frame pool (still in the box)
    Going to be set in 2.5' hole with deck at rail height sourounding entirely
    Cartridge filter ( we will see how that goes for one season)
    Natural gas heater and solar cover
    Plan to use bbb method! Yay!!
    Hi, thank you for these instructions. I'll be setting up a 16' round ultra this weekend. Dumb question, but do the pavers go directly on tarp/ground, not tarp/foam/ground, right? Meaning only the pool liner should be resting oh the tarp/foam, so I will need to cut foam inside of leg supports of pool. Is that right?
    Scott
    http://www.levelgroundpool.com/level-ground.html i used this in the past huge sucess
    Eaglei22's Avatar
    Apr 2017
    IL
    34
    Did you ever have any problems with sand washing away?
    Jul 2014
    Oakbank, Canada
    389
    Quote Originally Posted by cmbutterbaugh View Post
    Best thing we ever did was put 3/4" foam under ours, what a huge difference it makes.
    Quote Originally Posted by swolk View Post
    Scott
    Yes, that is correct. The foam should not be over the pavers, support legs need to sit on them directly.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
