Results 1 to 10 of 10
Thread: New 27' pool - where to start?
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Topic Split off by Moderator
    Okay- I'm following this post as I also just wrapped up my pool install last night- same size.
    I had my water tested- it shows
    Free Chlorine- 0.0
    Total Alk- 170
    PH- 7.4
    CYA- 10
    Based on the pool calculator- I would add 36 oz of bleach and 60 oz of solid stabilizer to begin a "TroubleFree Pool"
    Is that right?
    Intex 22' x 52" - Intex Krystal Clear Sand Filter Pump - flow rate: 2,150 gal per hour
    TFTest Kits TF-100
    Waiting to stop relocating until I build my dream pool!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New 27' pool - where to start?
    Well, what size gallons did you put in the pool calc? What were your targets?
    I'm not getting the same result as you but that could be because of the different results you may have entered.
    You want enough bleach to reach 2ppm each evening, until the CYA holds.
    This is a new fill, right, so how could there be CYA of 10?
    Do you have your own test kit yet?
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    In my calculations- I used 16177 gallons- that's what the manufacturers web site says. However- I calculated 17133 using my own formula.
    Okay- if I understand the pool calculator- to achieve a target FC of 2ppm- I would add 34 oz of bleach- yes?
    I do have a test kit- just haven't found it yet from the move- my readings were from a pool store- so the readings hopefully were accurate.
    This was a new fill.
    Any concern over the alkilinity?
    TFTest Kits TF-100
    11,969
    Lets say 17,000 - good enough for now.
    Alk is high, but that's nothing to be concerned with - high TA simply means the ph will drift up. So when it does, lower it. Each time the PH hits 7.8, lower it down to 7.2 with muratic acid. The pool calc will tell you how much acid to add. The acid additions will also lower the TA, eventually both will be in range.
    For chlorine - Add one small jug of bleach 6% each evening until the CYA is dissolved.
    For CYA , start with 4 lbs. Place 2 lbs in a sock at a time - and tie a knot in it, then tie it with string in front of the return. IT will dissolve from the sock - then you can retest for it in 5-7 days. Once the 4 lbs of CYA has dissolved from the sock, assume your level is 30 and adjust your FC levels accordingly - start targeting 4 ppm each evening to keep your FC above the "min" of 2 at all times.
    Hope this helps, post back if you need clarification.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    thanks! What do mean by "jug"-how many ounces is that? I've already added 32 oz.....add more upon adding the CYA? What do you do- dissolve 2 lbs first; then another 2 lbs?
    TFTest Kits TF-100
    11,969
    Walmart sells small jugs at 96 oz and large jugs at 182 oz. So you've added about 1/3 a jug, add the rest.
    Yep, 2lbs at a time, dangling in front of the return, leave the pump running 24/7 till it dissolves.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Okay- have added 96 oz of bleach and am on my second sock- no registerable chlorine in my tests. Keep going right? 96 oz per day until I'm up to 4 ppm?
    TFTest Kits TF-100
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    just checking (I know this is a basic question...sorry ) but is your pump running while adding the bleach and are you waiting 30 minutes before taking a sample to ensure the bleach has mixed thouroghly with your water?
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Yes- pouring slowly in front of the return. Waited 24 hours later to test. Since my post an hour ago- I've added the rest of my bleach. Now 192 oz since Saturday- and again on my second 2lb sock of CYA.
    TFTest Kits TF-100
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Today's measurements:
    FC- 2 ppm
    TA- 170
    PH- 7.5
    CYA- added my second 2lb sock yesterday morning
    Now, follow the pool calculator's recommendation to get my FC up to 4 ppm.....add 71 oz correct?
    TFTest Kits TF-100
