Thread: super blue
    Apr 2010
    Perry, Michigan
    81
    super blue
    The pool store is recommending we try something called "super blue." The lady said that it sticks to the sand and helps the finer particles adhere to it and helps to clean up the pool. Any opinion on this?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: super blue
    Its a clarifier.
    If your FC is holding overnight but you are still having some residual cloudiness, you can try clarifier.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Re: super blue
    If you are trying to get more of the fine particles out of the water you can add some DE to your filter. I did it about a month ago, and the water is so clear, even at night with the lights on . Look in the pool school under "adding DE to a sand filter".
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Apr 2010
    Perry, Michigan
    81
    Re: super blue
    Thanks! I am going to see if I can find the DE and try that in my pool.
    Aug 2009
    Close to Houston
    25
    Re: super blue
    I use the fiber clear, it seems to do pretty good and it's about 6 bucks a bag.
    18' above ground from Leslies
    Hayward sand filter (100 lbs) with 50 lbs Zeosand
    1 HP pump
