Thread: Flow level changes overnight?
    Feb 2008
    Milford, CT
    337
    Ive noticed this since I made the higher flow mod to my LQ: one day I can set the flow at 3 on the flow meter. Everything seems to work fine, no air in the system, etc. Enough flow that I can peg the meter if I want.
    Let it run for the rest of the on cycle and its fine. The next day Ill look and see the flow meter at 2 or lower. Nothing changed, just the fact the filter/pump cycled off and then back on. Ive also checked after the filter was running for a while the next day just to be sure it wasnt a priming issue as the pump started up.
    Any ideas?
    Thanks.
    -Chris
    22K IG vinyl, MaxFlow SP2302VSP pump, S244T filter, AutoPilot Digital w/SC-48 cell
    22,553
    Re: Flow level changes overnight?
    I haven't noticed that with mine. Where did you tap the suction side into? I tapped into the suction pipe instead of the basket drain plug. I don't know if that would make a difference.
    Feb 2008
    Milford, CT
    337
    The suction side has always been tapped from the basket drain plug.
    When I did the mod I changed from the valve HASA included (that you need to drill into the PVC for) to a PVC tee, with a threaded bushing and a 3/8" nipple (same as the one used on each end of the flow meter) screwed into it. Seems odd that would have made any difference, I can still get as much flow as I need (and more) but it just doesnt seem to keep the same rate from day to day. This is also with the same psi reading on the filter.
    -Chris
    22,553
    That is odd. I noticed mine do it once but I found a very small piece of plastic that I dropped in the vat had gotten in the flow meter. I cleaned everything out good and it's been fine since.
