Results 1 to 8 of 8
Thread: How do my numbers look?
    linda1's Avatar
    Mar 2010
    Western Pa.
    300
    Any advice? Don't know why I feel so intimated by all this! And my DH must think I'm nuts as I flew out of bed this morning saying "got to beat the sun".
    Last night:
    fc- 5.5
    cc- .5
    This morning
    fc- 5
    cc- .5
    Ph- 7.2
    ta- 80
    ch- 20
    cya- 20 (I added this on the 10th, and not sure if I should wait awhile longer to add more)
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    22,553
    Re: How do my numbers look?
    Feeling intimidated is normal when you're learning something new and foreign to you. With time and parctice it'll become second nature. Hang in there.
    Your numbers look good. Personally I would hold the FC close to shock to see if I could get that last little bit of CC to go away.
    How much CYA did you add? What value were shooting for? I'd think 5 days would be enough time for it to be mostly dissolved but if the goal was much higher than you're seeing, give it another few days.
    linda1's Avatar
    Mar 2010
    Western Pa.
    300
    Thanks
    I added 4 pounds of 96% cya. My goal was 30.
    22,553
    I'd give it a couple more days and test it again, then add more from there.
    linda1's Avatar
    Mar 2010
    Western Pa.
    300
    Just double checking. My shock level would be 10 and I would need to add 185 0z of 6% bleach and I should do this now or tonight?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by linda1
    Yep, shock 10. I'd shock tonight/this eve - after the sun is off the pool
    There's a possibility the CC will be burned off by the sun today.
    You're done SLAMing when:
    linda1's Avatar
    Mar 2010
    Western Pa.
    300
    Ok, thanks a bunch!
    22,553
    I noticed on another thread you said you'd just took the solar cover off a day or two ago, so that may be the reason for the CC's. They just may need time to gas out.
