Thread: Hoses and Duct Tape
    Hoses and Duct Tape
    The hose from my pump to my filter refuses to stay on. It always comes off on the pump even though I have two clamps on it. My solution was duct tape around the base of the hose and the pump. It works like a charm. Is this an acceptable solution, or am I doing something wrong altogether? Is it frowned upon in the pool community?
    11000 gallon Viking Fiberglass 12 x 28, Intellichlor IC-40 SWG, 24" cascade fountain, 12" cascade fountain, 1 1/2 HP pump, sand filter
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Hoses and Duct Tape
    sounds like something is wrong, duct tape can melt off in warm conditions. post a picture of your setup and we can help you better.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Sounds like the hose is bigger than the nipple. Duct tape filler probably won't last. Time to break out the ruler and make a visit to the hardware store.
    My hoses were the correct size. Turns out, a threaded hose adapter with barbs on one end solved the problem. On to the next issue!
