Thread: high salt/amps
    high salt/amps
    I have agualogic system - I'm getting a check system high salt/amps reading. What do I do? Do I need to have it serviced? I don't understand the manual. I have drained and added more water to lower the salt to 3600. What does the diagnostics 25v 5A mean?
    18x36 Rectangle dual drains in floor
    Digital Autopilot SWG
    AqualCal Heat Pump
    1.5 Horsepowered pool pump
    mas985's Avatar
    Pleasanton, CA
    11,559
    Re: high salt/amps
    You will get a high salt error when the salt is too high or the water temperature is suddenly really high as would occur with solar turning on or a heater turning on. Also, if you just added salt you might wait a day or two to see if the salt will circulate and dilute.
    To reset the warning and see if it occurs again, go to Diagnostic Menu and click right button then click + button. This will reset the SWG. After the SWG starts, see if it reads high salt again.
    Mark
    Nov 2007
    Rockland County, NY
    65
    Re: high salt/amps
    Tammyill,
    I think we need more information to answer your question. Did you just add salt to your pool? Do you have an attatched spa? Is the heater on when this happens? A complete description of your pool, equipment and recent chemistry would help alot.
    Rob
    27ft Above Ground Pool
    Sand filter
