Thread: Cracked Hayward C5025 Swimclear cartridge filter
    Uh oh -
    Either thru overtightening and/or degradation to the fiberglas -- the housing around the drain plug has small cracks in it and I cannot get a seal (replaced the drain plug/Oring).
    If I'm screwed and need to get a new housing (5 years old - 4 paper cylinders) should I switch to more efficient, easier to clean an service unit? What would that be? I don't think there is a bondo solution for this? Threads are still good.
    A new unit of this type is ~ 800 bucks.
    Bob
    Thanks As Always!
    Bob
    23,000 gal in-ground, Aquarite salt sys, Intellitouch i7 +3, Hayward cartridge filter (4) C-5025, Polaris 280 Pool Cleaner, 3/4 HP booster pump, Hydrazzo plaster.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Cracked Hayward C5025 Swimclear cartridge filter
    Have you been happy with this filter? If not you may want to consider a new filter. Either another cartridge filter or a different filter medium should work fine unless you have special circumstances that would indicate one media as better suited for your pool than another. If you want to try and save this filter you could try an epoxy such as JB Weld to repair the cracks. You would need to empty the filter and dry it off well and sand the surface lightly. It will work best if you epoxy it with the plug in place. Of course, you won't be able to open the drain anymore, but you can always siphon it out!
    Love TFP? Become a
    TFP Supporter!
    If I were in your shoes, and was happy with the performance of the filter, I would look into buying a replacement part for the filter housing. I am thinking it is the base of the housing. If so, it can be found for about 3 bills. If you decide to get a different filter, then you must figure in the possibility of plumbing re-do. I have had Hayward and Pentair cartridge filters and both have worked fine. I have no preference. If the filter housing on my existing filter failed, I would repair/replace damaged part before replacing the entire filter assy. JMHO.
    16K gallon, Pebble tec, beach entry. Two 1 hp Pentair Whisperflos. One for Paramount MDX2 main drain, Paramount debris canister, and Pentair CCP 520 filter. One for skimmer w/sock and Paramount PCC2000 in floor cleaner. 3/4 hp Pentair Pinnacle for waterfall. Fiberstars fiber optic pool lighting. Aqua-Logic AQL-P-4 control panel with wired remote in the house. SWCG system that is not used. Ultra-Pure Ozonator that is not used.
    Thanks! I was remebering back to people talking about sand filters (other designs?) My wife had unfortunately selected natural slate tiles for the walls around the pool (built into hill) and this degrades to sand and MUD. So I am forever hose blasting in between the paper slats. Though maybe there was an easier to clean filtration system. If worse comes to worse I gues I will epoxy the hole shut and work with it that way until I research other filters or decide on new housing or new same filter. I think this fiberglas housing does not ultimately weather well.
    Thanks As Always!
    Bob
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Hmmm. Mine is going on 9 years...knock on wood....
