Results 1 to 8 of 8
Thread: Do those solar pills or solar rings actually work?
    Hi There! We have a 27' round pool (second season) with a Fafco 4x20 solar panel. We are adding another 4x20 panel on this year.
    Trying to decide whether to get a solar cover or try those solar rings or the solar pill.
    I'm thinking the cover is the best, but I'm short 5'2" and hubby is not home during the day when I would need to get it off for the kids and I to swim.
    Curious on what others have found with these?
    Also...should I get a lighter weight (12mil) cover if we go the cover route since it would be less heavy to manuver?
    Thanks for your input!!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: Do those solar pills or solar rings actually work?
    yup the pills do not work....very little if at all. Given your situation and size of pool, I would advise using the lighter solar cover. Adding the 2nd panel will help alot...3 panels would probably be perfect for a 27ft pool...I'm just in the process of adding a 2nd to my 24ft
    i am fairly new at this...but I purchased a solar cover two weeks ago and it rocks...if you will not have help taking it off...you will need a reel...Although there was a discussion on here a month ago about cutting them in half
    Grant and Jerri
    Liberty, NC
    New 18x36 vinyl liner pool with lighting and fountain
    Jul 2009
    London and France
    574
    Solar rings, save your money, more hassle than they are worth.
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    I agree about the pills, don't waste your money on them. I don't think they made any difference at all when I used them. I think the reel for your solar cover is your best bet.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    A solar cover was included in my pool package when I bought my pool. Used it twice before I realized it was WAY too much effort to get on and off without a reel. I then realized, I live in central Florida and don't really need a solar cover because I can usually swim all the way through October before closing the pool. I reopened in March this year, but it was a bit cooler than normal.
    I agree with the others though, either get a reel or get the lighter one. It was a lot harder for me to remove than I thought it was going to be.
    24' Round AGP | 13,600 Gallons | Waterway Cartridge Filter | Waterway 2 Speed Pump | K-2006 Test Kit
    100% Trouble Free Since The Baqua Conversion
    Jul 2009
    Seattle, WA
    89
    You can also cut the cover into manageable pieces.
    20,000 Gallon kidney sort of a sand filtered gunite in ground pool w/ hot tub.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    The solar cover will keep the heat in that you generate with your panels as well as keeping crud out when you aren't swimming. Saves on cleaning.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
