Thread: Intelichlor IC40 just installed
    tested chlorine first time with TFTest kit and indicates no chlorine is being made
    I have intelichlor IC40 just installed this winter
    salt level at 3900 ppm all lights green
    T/A 290
    17,000 gallons
    sand filter, IG, vinyl
    Jul 2007
    North Texas
    55
    Re: Problem with Intelli
    Pull sample in front of return while cell light is on. Unit could be working fine, lots of variables to consider.
    Re: Intelichlor IC40 just installed
    You should post a full set of water test results and do a visual inspection of the cell plates looking to see if you have any white chalky deposits on the plates. Also, what does the pool water look like?
    Rocklin, Ca
    467
    You need to start with with some chlorine in the pool. A SWG is not designed to start from scratch. They are made to maintain you CL level in a healthy pool. Try adding bleach or liquid chlorine until you get up to the 3-5ppm range, depending on your CYA level.
    Jason and tmoss both gave good advice as well.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by paulj
    T/A 290
    Retest the TA. Wipe the tip of the R-009 dropper bottle in between each drop with a damp cloth. See if you get a lower result...
