Thread: low or non-phosphate scale-stain product
    Aug 2008
    Honolulu
    429
    In this article here:
    http://www.mcgrayel.com/files/Phosph..._and_Myths.pdf
    and in this discussion:
    http://www.troublefreepool.com/phosp...em-t16805.html
    It states one should use low or non-phosphate scale-stain product, are the Trouble Free Pool's recommended sequestrants of this ilk?
    If not is it still ok to use them or should one put phosphate remover in the water some time after they are used?
    Thank you.
    10,000 gal plaster pool,3/4 hp WhisperFlo pump, Sta-Rite Great White GW9500 pool cleaner, Hayward 300 lb Sand Filter
    Use Magenta Stuff for Iron and Silica control.
    Balance: pH 7.7 Cl 7 -8 Alk 70-80 CH 325 CyA 30 in winter - 50 in summer NaCl 1010 TDS 1200
    Re: low or non-phosphate scale-stain product
    Having some phosphates in the water is not a problem at all. While eliminating phosphates from the water can slow or stop algae growth, it doesn't protect you from bacteria or viruses, for which you need chlorine. Chlorine alone completely stops algae and bacteria and viruses, so there isn't much point in spending money on phosphate removers when chlorine does everything you need done for less money and more simply.
    All of the best sequestrants contain phosphates.
    Aug 2008
    Honolulu
    429
    Thank you for your quick clear and concise reply.
    Duly noted.
    Aloha.
