Results 1 to 8 of 8
Thread: opening pool
    Jul 2008
    West Point, VA
    29
    opening pool
    So, we pulled the cover off the pool today. We have several tasks at hand: fill up the pool and get everything connected so we can run the filter, figure out how to handle the tons of tadpoles and frog eggs, and try to determine if there is a leak in the liner because the water level is quite a bit lower since we closed it.
    What can prevent the tadpoles/frogs/frog eggs from overtaking our pool again?
    Any suggestions on finding leaks in above ground pool liners, when there is no obvious water from the outside? If its small, can it be repaired, or should I look now into a liner replacement?
    Will test the water tomorrow as we work to add more water to get the levels right.
    24' round AG vinyl liner
    200 lb/26" Baquapure sand filter with 2.5 HP pump
    converted to BBB end of 2008 season, and it's worth it!!
    Re: opening pool
    Is it possible that you had a leak in the cover? That is more likely than a leak in the pool.
    Jul 2008
    West Point, VA
    29
    Re: opening pool
    Yes, we think that might be the case, so we are hoping we just pumped out water from the pool when trying to drain it from the top of the cover.
    Jul 2008
    West Point, VA
    29
    Re: opening pool
    the pool turned out gorgeous! we didn't find a leak, don't seem to be losing water, and I still LOVE the BBB method. I can't stop talking about how great the pool looks.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: opening pool
    Looks downright sparkly!
    30,403
    Re: opening pool
    Very Nice Work!! That's a pretty pool!
    Ashbourne's Avatar
    Western Piedmont, NC
    109
    Re: opening pool
    Wow, beautiful!
    18x36 IG Vinyl, 8.5 deep, 28K, Hayward C4025 SwimClear Filter, Hayward SP2607X10 Super Pump 1HP
    22,543
    Re: opening pool
    OMG, you store your vacuum plate the same place I store ours!
    Your water looks great too!
