Results 1 to 13 of 13
Thread: no chlorine being made
    tested chlorine first time with TFTest kit and indicates no chlorine is being made
    I have intelichlor IC40 just installed this winter
    salt level at 3900 ppm
    17,000 gallons
    sand filter, IG, vinyl
    Feb 2008
    Denton, TX
    5,061
    Re: no chlorine being made
    Can you post a full set of test results for us? Include the salt level and the water temperature as well. Are you getting any error messages from your Intellichlor?
    Feb 2010
    Blessing, Tx (South of Houston)
    82
    Where are you located and what temp is that water? Most (if not all) SWG's will shutdown and not product below a certain temp
    Intex 18' AGP - Intex SWG - 19 inch Sand Dollar Sand Filter - 1HP Pentair Dynamo Pump - 4X20 Solar Panel - Goldline Solar Controller.
    Quote Originally Posted by 257WbyMag
    FC 0
    CC 0
    T/A 290
    Ch 180 water temp 85 deg F no error messages all lights green salt level 3900 ppm
    17,000 gallons
    Quote Originally Posted by Dale.s
    I am located in Georgia and the water is warm
    ph is high, and cya doesn't register at all
    17,000 gallons
    If CYA is low, will this cause FC to be 0?
    17,000 gallons
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Quote Originally Posted by paulj
    If you don't have CYA and you have algae or other contaminants in the pool, the chlorine could be used up quickly. Turn your chlorinator up and run the pump all night. Check the chlorine first thing on the morning to see if you are making any.
    ETA: Either way, you need to raise your chlorine level manually to avoid an algae bloom.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    OR stick a hose on the end of a return and fill up a bucket... test teh bucket for FC or CC. If you have some, its working! It just cant keep up at the moment, you may want to shock with liquid chlorine if this is the case to let it "get ahead" of the algae.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Feb 2008
    Denton, TX
    5,061
    Yes, without CYA, you will lose your entire amount of FC to the sunlight in just a few hours.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Without CYA the chlorine will burn off fast! This site recommends a CYA level of 60-90 for pools with salt water chlorine generators. If you do not have any CYA in the water you will need to add some to bring it within range. It is probably burning off before it has a chance to accumulate enough to register on the tests. You will want to add chlorine manually until you add enough CYA to allow the chlorine to accumulate. How high is your pH?
    Love TFP? Become a
    TFP Supporter!
    Quote Originally Posted by zea3
    pH is 8.2 will that affect CC?
    how is the best way to raise CYA?
    17,000 gallons
    Feb 2008
    Denton, TX
    5,061
    That's a very high pH. You should lower it to 7.2 and go ahead and shock your pool with bleach. pH does not affect CC. The reason that you should shock right now is because you have a very warm pool and nothing to keep an algae bloom from starting.
    CYA, known as cyanuric acid, can be purchased at most places that sell pool chemicals. It is often listed as stabilizer. Read the ingredients and make sure that you get as close to 100% CYA as possible.
    Dec 2009
    Central Massachusetts
    2,690
    Is your IC-40 hooked up to an intellitouch or is it stand alone? If you turn it up to 100%, and everything is correct, you should get a green flow light, green salt light, green cell light, and a green 100% light. What do the indicator lights show?
    Edit: ok i just saw where you said all lights are green. Try the hose idea. That should tell you if you are making chlorine. As others have said, you need some CYA in the water.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
