Thread: Lesson Learned....
    Baton Rouge, LA
    237
    Lesson Learned....
    Lesson: If you keep adding chemical, and your test continues to show no change, at some point you need to doubt your test.
    New pool. New test kit.
    Not using salt yet.
    Add calculated volume of bleach. A little change, up to .5 ppm.
    Continuing to add cya, meanwhile adding more bleach.
    And more bleach.
    And more bleach.
    Still .5 ppm Cl.
    Wife: I'm beginning to doubt our test kit. I'm going to WalMart and buy another kit or more reagent.
    New kit: Well over 5 pmm Cl. (last night)
    This morning: Report from her lab: Well over 5 ppm
    Evidently Cl reagent can go bad (or if not bad, at least neutral... which is.... bad), and sometimes does. Know that.
    Steve
    18,000 gallon gunite free form, with spa, 4x160, EasyTouch, SWCG, Pentair cartr filter, Colorlogic lights.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Congratulations on passing your class in "Learning, the hard way." Whenever chemicals don't do what I think they should, I try adding them to a bucket of water and testing that. The small scale lets me make big changes in levels easily to see if things make sense.
    Baton Rouge, LA
    237
    yep... my wife mentioned that she had meant to try adding a drop of bleach to the test to see the reaction... but it had slipped somehow....
    must've slipped between doing the laundry, cooking dinner, work... or one of those cracks...
    my naive self never doubted the test.
    Jul 2007
    Florida
    64
    When you said "new kit," you meant the TF100 sold here or a walmart kit? In the case of walmart kits, who knows how long they've been sitting in storage and/or on the shelves.
    22,000 gal in-ground, 3-8ft
    Cartridge filter
    Pebble Tec resurfaced
    Polaris 360
    Montreal Canada
    326
    Quick tip: The R-0002 reagent coming out of the bottle should be a clear liquid. If it's pink or wine color it has oxidized and should be discarted.
    Baton Rouge, LA
    237
    The walmart one was the accurate one in this case.
