Results 1 to 9 of 9
Thread: Course of action for pink algae
    Bucks Count PA
    73
    What would be the course of action if I have pink algae in the deep end by the pool light.
    Cl 5
    CC 0
    Cya 50
    PH 7.6
    Alk 80
    Calcium 160
    I know I saw some a post that list different shock levels for different types of algae but I can't just find it.
    Inground Grecian 20,000 gallons vinyl liner
    Hayward 250 BTU Propane heater
    Hayward DE Filter
    1 HP Northstar Pump
    Spill Over Spa
    Bucks Count PA
    73
    Re: Course of action for pink algae
    Would adding borates to the pool help reduce the chances of this pink algae returning once I get rid of it?
    Hayward DE Filter
    1 HP Northstar Pump
    Spill Over Spa
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    It might. Go ahead and shock your pool, brushing daily the problem areas until the FC holds overnight and visible traces are gone.
    Are you experiencing unsually high chlorine demand?
    Bucks Count PA
    73
    Yes it has been difficult to keep the chlorine up but there was no CC when I tested so I just couldn't figure it out. Now that I see the pink algae(or whatever it is is) I assume that is what is eating up the algae.
    Hayward DE Filter
    1 HP Northstar Pump
    Spill Over Spa
    11,969
    There isn't always a CC reading when there is algae. Confusing I know...
    Butterfly's Avatar
    South Carolina
    10,045
    Use Google (bottom left on page) for pink bacteria & you'll get some more info.
    Let us know how it goes.
    You're done SLAMing when:
    You fight pink algae the same way you would real algae, shock the pool. As long as your have proper FC levels and good circulation it should go away and stay away.
    Pink algae, as others have already mentioned, is actually a bacteria. It is very rare for chlorine pools to get pink algae, because it can only get going at extremely low FC levels. It is far more common in baquacil pools.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Quote Originally Posted by sunnydays
    It's near the bottom of The Pool Calculator, a bright blue box.
    Bucks Count PA
    73
    Thanks Richard must have looked over that many times.
    Been shocking the pool since last night added more bleach this am to bring it up to shock level. I will continue to do so until the chlorine holds over night.
    Yanked out the deep end ladder and it was all over the bottom of the ladder. So I will brush it with a bleach solution this weekend before I put it in. Also bleach the skimmer, return jets, aroung the pool light and the steps. I really want to hit all the crevices this thing could be hiding.
    Hayward DE Filter
    1 HP Northstar Pump
    Spill Over Spa
