Thread: CYA Reading
    CYA Reading
    3.5 lbs of CYA finished dissolving in my skimmer yesterday evening. What's the likelihood that I could get an accurate reading if I took a water sample to the pool store this morning?
    Alan
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: CYA Reading
    minimal.
    Assume your level is whatever your target is.
    So if you added enough to reach 30, your level is 30...and adjust FC levels accordingly.
    Feb 2010
    Blessing, Tx (South of Houston)
    82
    Re: CYA Reading
    Even if it looks like its dissolved, chances are it isnt, a lot will be in the filter, the rest will just be suspended in the water. After say 5 days or so you should get a accurate reading. Just assume its what you aimed at for now, then retest next week.
    Intex 18' AGP - Intex SWG - 19 inch Sand Dollar Sand Filter - 1HP Pentair Dynamo Pump - 4X20 Solar Panel - Goldline Solar Controller.
    Re: CYA Reading
    Should I not backwash until I'm confident I've achieved my desired level?
    Alan
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: CYA Reading
    Correct. You'll likely flush a bunch of it away.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: CYA Reading
    If you need to add CYA and think you may also need to backwash, it would be better to add it with a sock hanging in front of a return.
    You will still lose some CYA when backwashing, just minimal amount that you would ordinarily lose anytime you backwash.
    You're done SLAMing when:
