Thread: Nitrates and CYA ?
    Nitrates and CYA ?
    Four questions
    1. Will the nitrogen contained in the CYA eventually show up as nitrates in the pool?
    2. If not, is it the nitrogen in the CYA that makes chlorine less effective above 60 ppm CYA?
    3. Will the chloramines that some municipalities add to the water supply eventually show up as nitrates in the pool?
    4. Will the ammonia contained in quat algaecides eventually show up as nitrates in the pool?
    ~25,515 gal, IG Free Form/Gunite, Riversand Tahoe Blue Pebble Finish, SR Smith 6ft Diving Board, Swim Out, 8ft Bench, 8ft Weeping Wall, Raised 18" Stone Spa w/3 Tier Spillway, 6 Hydrotherapy Jets, Sunken Tanning Ledge, Boulder Coping-Garden, Oklahoma Flagstone Coping-Decking, 589Sqft Stamped Concrete Decking~ Intelliflo VS+SVRS 3hp pump, Jandy 60sqft DE Filter, Jandy Aqualink PDA PS6 Controller, Rainbow 320 Chlorinator, Polaris 280 BlackMax w/PB4 Booster Pump, Nature 2 Mineral Sanitizer G45, Del Ozonator-Eclipse 2, Laars LXi400 400k btu NG Heater, 1.5HP QT Blower (Spa)
    Re: Nitrates and CYA ?
    Welcome to TFP!
    In the long run all of the nitrogen will be outgassed as nitrogen gas. Nitrogen from ammonia and chloramines does this relatively quickly, nitrogen from CYA does it quite slowly. In the mean time, some very small portion of the nitrogen might react with something else to form nitrates, but that is fairly unlikely (ie doesn't happen very much at all).
    CYA makes chlorine less effective at any CYA level above zero. This is a property of CYA as a whole, and is not related to anything nitrogen does on it's own. You need to compensate for this by using a higher FC level the higher your CYA level.
    Mar 2007
    San Rafael, CA USA
    (writing what I wrote in an E-mail that had the same questions ... some repetition with what Jason wrote)
    CYA is usually only reduced through water dilution such as splash-out, carry-out, rain overflow, backwashing and intentional partial or full drain/refill.
    CYA does slowly get oxidized by chlorine, but that process results mostly in nitrogen gas, carbon dioxide gas, and water. Nitrates are a minor side reaction to most chlorine reactions oxidizing nitrogenous components including ammonia and urea from sweat and urine. Yes, nitrates do form, but not that much, though they do accumulate.
    The effectiveness of chlorine in the presence of CYA gets reduced by ANY CYA in the water, not just 60 ppm. It's a chemical equilibrium between chlorine being bound to CYA vs. chlorine being unbound. Most of the chlorine is bound to CYA. In a pool with pH 7.5, FC 3 ppm and CYA 30 ppm, 97.2% of the chlorine is bound to CYA while 1.4% is the active killing form of chlorine hypochlorous acid and 1.4% is the less active form called hypochlorite ion. A rough approximation of the equivalent amount of active chlorine is the FC/CYA ratio where with 3 ppm FC and 30 ppm CYA this is roughly equivalent to a pool with 3/30 = 0.1 ppm FC and no CYA. So you can see that as the CYA level increases, the FC level must proportionately be increased to maintain the same level of sanitation/disinfection and rate of oxidation. This has absolutely nothing to do with nitrates.
    A small amount of the chloramine in water supplies will end up as nitrates when oxidized by chlorine in the pool, just as with any nitrogenous source that chlorine then oxidizes. For example, for chlorine oxidation of ammonia at typical levels, 89% of the nitrogen ends up as nitrogen gas while around 10% results in nitrate and less than 1% results in nitrogen trichloride. So yes, nitrates do form and they do accumulate, but they really are not an issue.
    Yes, linear quat and PolyQuat algaecides will also break down and they too will form mostly nitrogen gas, but also some nitrates.
    Why all this concern with nitrates? They are not a problem. Nitrates and phosphates are food for algae, but chlorine alone can kill algae faster than it can grow even in the presence of lots and lots of phosphates and nitrates. My pool has had 2000-3000 ppb phosphates and though is very reactive if the FC/CYA ratio gets too low, so long at the proper level is maintained algae does not grow.
    [EDIT] Remember that most chlorine usage is from breakdown from the UV in sunlight. The amount used to oxidize bather waste and other organics in the pool is probably less than 0.5 ppm FC per day in most cases. This would roughly mean the equivalent of around 0.05 ppm ammonia and would result in 0.005 ppm nitrates as ppm-N or around 0.022 ppm nitrate as ppm nitrate. So over time, clearly nitrates can build up, though this is rather slow -- 4.0 ppm nitrate over 6 months in a residential pool with no water dilution (and this is conservative). Again, nitrates are not a problem just as phosphates are not a problem. Chlorine alone can kill algae faster than it can reproduce even in the presence of all the phosphates and nitrates it could ever use -- algae growth is then limited by sunlight and temperature. [END-EDIT]
