Thread: Lateral broke, now what?
    Apr 2010
    Phoenix, AZ
    5
    In the process of replacing the sand in my filter, I removed the laterals. #7 gave me a hard time screwing it back in and I heard the plastic crack. I tried to take it back out and it really broke. In the process of trying to get the stupid thing out the only piece left is the threaded piece and I've tried everything trying to get it out without damaging the threads to no avail. Has this happened to anyone here? How did you fix it? At this point I am almost ready to block it off. Taking it apart isn't an option, it works fine, so I won't tempt fate. At this point I am almost ready to block it off.
    Filter is a Pentair Titan with the 8inch opening at the top and the diffuser that pivots to one side.[attachment=0:2gshoxmq]Filter.tif[/attachment:2gshoxmq]
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Lateral broke, now what?
    The pic isn't showing up.
    Try using photobucket.com or a similar host site and upload your pictures there, then copy and paste the IMG code to your message here.
    22,553
    They make internal pipe wrenches that you can use to remove the broken piece.
