Thread: CYA test
    Aug 2009
    Close to Houston
    CYA test
    OK, I just got my CYA test today and ran it twice. I got about 25 both times which is what I kinda expected. I have the chlorine test already and can take TA and pH at work. CYA was the only other thing I really needed to test for but I thought I could get this from the pool store every so often so I didn't buy it. I had taken 2 different samples in to the store about 2 weeks apart and both times they got 100 and it was 2 different employees. I guess my question is am I doing my test right or can they be that far off? Do I keep going until the black dot is completely gone? Should I be in sunlight to look at the test or is normal inside lighting OK?
    Thanks for the help,
    18' above ground from Leslies
    Hayward sand filter (100 lbs) with 50 lbs Zeosand
    1 HP pump
    Re: CYA test
    The CYA test is designed to be read in indirect sunlight. Using indoor lighting you will tend to get a slightly higher reading that you would outdoors.
    Pool stores are frequently way off.
    Yes, the black dot should be totally gone, no evidence of it having ever been there even after looking for a couple of seconds.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    Re: CYA test
    My favorite CYA test tip:
    After you test in the indirect sunlight, pour the solution back in the mixing bottle, and do the black dot search again. Then repeat. That way you are more confident in your result. And it saves on reagent...cuz I'm cheap, errr, thrifty on that kind of stuff.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump Liquidator TFT100 test kit
    Butterfly's Avatar
    South Carolina
    Re: CYA test
    Hi Roger,
    Along with the good info you have already gotten, here's a link to Taylor's instructions, including pics of the test that have really helped lots of us ... ntentID=36
    You're done SLAMing when:
