Thread: Polaris 360 Problems
    For some reason, tail on the back of my Polaris stopped swinging back and's just dragging behind the Polaris. Any ideas or suggestions?
    Re: Polaris 360 Problems
    Is the booster pump on? There is also an adjustment knob where the hose plugs into the pool try adjusting that.
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Check to make sure end of insert at end of whip tail did not fall out.
