Thread: Weird Blue and Gray Spots on the walls of the pool
    Thank you for everyone's green pool problem. I'm finally getting good readings on my chemistry. Now I have another problem, but was not sure whether I should start a new thread since it is a separate problem or continue on the old one. If I was suppose to continue on the old one, I apologize and could the Mod kindly merge this with "trying to restore green pool" thread.
    Well I see weird discoloration on the walls and the steps of my pool as you can see in 1.jpg attached. Is this something that can be corrected by treating the water or is it something what will have to be repainted?
    Second minor question is, what is that pipe sticking up from the middle of my cartridge filter in 2.jpg?
    Pool Size: 10,000 gallons
    Pool type: Plaster
    Pump: Centriflow 2.0HP
    Filter: Cartridge Filter (Posi-flo II)
    Oct 2007
    Cedar Hill, TN
    251
    Re: Weird Blue and Gray Spots on the walls of the pool
    Don't know about the spots, but the pipe in your filter looks like it's there to help the cartridge stay centered when you put the top back on.
    (This is my guess, since I have a sand filter with a pipe sticking up, for centering the valve assembly.)
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    It's an air bleed tube with filter.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    "repainted"?
    Can you add your pool specs/equipment to your signature... go to User Control Panel, then Profile, then Edit Signature.
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Quote Originally Posted by TripleB4me
    yep
    First question the pic is hard to determine what you are asking. What kind of pool do you have? What was the original color of the pool, do the spots come off or does it looked like it is chipped off?
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Quote Originally Posted by whoozer
    yep
    Not sure what the original color was. I'm assuming blue? I tried scrubbing it with a brush, but it doesn't seem to be coming off. It is a concrete pool? there's no vinyl liner or anything.
    Pool type: Plaster
