Thread: Am. Products Amerilite replacement?
    Looking to replace the entire light with about the same- can I go with any other brand (are they standard?) ..Where is a good place to buy a light (besides Leslie's and online)?
    Re: Am. Products Amerilite replacement?
    The voltage supply has to be the same as well as the diameter of the hole. Weather or not the housing is plastered in place etc. may pose a issue. It may be possible to change the " guts " out providing any mounting screws etc. line up correctly.
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    The original label is worn so I can see that it is 120Volts but I can't make out the watts - does the wattage matter?
