Thread: Help with levels in pool
    Opened my pool up this year a week ago, after finally getting my new sand filter up and running. 18 x 36 kidney shaped pool. Removed cover. Filled pool up to desired level. Poured 2 1lb bags of pool time 4 in 1 shock plus treatment in on the first day. 2nd day poured one more 1 lb bag in. Algaecide placed on the first and 2nd day of opening. This was one week ago. Checked the chemical balance today and this is what i get. pH 6.8, total bromine 10, free chlorine 3, total alkalinity 180. I added some pH increaser today, but not real sure about how to correct the other issues. I have not put any bromine in the pool to my knowledge.
    So how can I correct the alkalinity and bromine levels??? Thanks for the help in advance!
    adam
    Re: Help with levels in pool
    Just ignore the bromine reading. Chlorine will test as bromine, so you are really just seeing the chlorine level in different units.
    TA at 180 is a a bit high, but might not cause a problem. If your PH tends to go up rapidly, then read How To Lower Total Alkalinity.
    THANKS Jason!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by ahogue142
    adam
    Hi Adam-
    Were the 4 in 1 shock bags a Dichlor-product (which contains CYA)?
    How does your water look? And is the FC holding overnight?
    Jun 2007
    NC
    255
    Quote Originally Posted by frustratedpoolmom
    FPM:
    Per the MSDS (RPTM22809) it's dichloro-s-triazinetrione, 58%. It's supposed to have a clarifier and flocculant built into it, but the MSDS doesn't state anything about that; just dichlor.
    "a little bit of chlorine, a lot of CYA, and a little bit of acid (PH=5.0-5.5) all in a handy pouch"
    Terry in NC
    ...are we having fun yet ???
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
